do a search on ebay, you can buy them for about $10. Its not a good idea to run your motor out of the water because #1 the impeller that is pulling the water to your motor is rubber and will burn if no water keeps it lubed #2 the motor is not being cooled #3 if its in gear you can destroy your strut bearing and shaft seal, both of which use water to lubricate.
