Phaeton, thanks for the info, I am curious, do you run the cavitation plate down the whole time or just under the higer elevations..and do you see a lot of problems in the performance of the boat with that big of a prop...it just seems huge!
Bsflower, thanks for the info as well, when you run the 600lbs under the seat, do you use water or lead? and what is the total weight that you use?? also, what prop do you use and have you seen any performance issues? Lastly, I'm helping in setting up the new service for the dealer down here....I'm hoping that everything goes as plans...we've got 14 boats, and I'm just trying to learn everything that I can to get things up and running!
jlembas, do you know exactly how Jimmy loads his boat? I've heard a lot of things about his boat, but I don't know how he lays it out..and someone sent me his ph# but it was not working....any idea of an email address that you could email me?
Switch, yeah I'm pretty excited! I'll have this dialed in now time.....see you out on the water this year and at INT.
Thanks again all for your input!
G~
