Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 18, 2009
Old     (seaswirlmike)      Join Date: Nov 2003       06-26-2008, 1:45 PM Reply
so the first holder to melt was the type that you strip your wire back and tighten an allen head on the side for your connection point on both sides. the second was a stinger fuse holder with crimp battery style eye connector connection.
what ends up happening is where the wire actually connects to the holder it gets hot at melts the holder. the fuse never blows which it shouldn't it is correctly sized.
I know pulling over 200amps is going to create so heat but I'm interested in some options in alternative fuse holders. I've heard some people even make their own for custom installs and would love to see some pictures if anyone has any. what type of anl holder do you use? anyone else experience similar problems
Old     (acurtis_ttu)      Join Date: May 2004       06-26-2008, 1:56 PM Reply
Have you tried the stinger 200 amp circuit breakers? You can buy the Metra brand ones for abotu 1/3 the price.
Make sure you have the correct size wire. The only time I've seen this happen is when people try and mount tower lights with to small wire.
Old     (acurtis_ttu)      Join Date: May 2004       06-26-2008, 1:58 PM Reply
http://cgi.ebay.com/PREMIUM-CIRCUIT-BREAKER-12-VOLT-CAR-AUDIO-200-Amp-CB200_W0QQitemZ360063308949QQihZ023QQcategoryZ3281 3QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/STINGER-HIGH-CURRENT-CAR-AUDIO-CIRCUIT-BREAKER-SCB150_W0QQitemZ310060651145QQihZ021QQcategoryZ328 13QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Old     (kenteck)      Join Date: Jan 2005       06-26-2008, 2:17 PM Reply
what are you using the ANL for? sounds like all you need to do is run bigger guage wire...
Old     (sigmodes)      Join Date: Jul 2007       06-26-2008, 2:21 PM Reply
What size wire is it? 4g max is 150amp 0g 250amp
Old     (seaswirlmike)      Join Date: Nov 2003       06-26-2008, 2:40 PM Reply
0g wire with a 300amp anl to three JL 1000/'s
Old     (seaswirlmike)      Join Date: Nov 2003       06-26-2008, 2:43 PM Reply
Old     (acurtis_ttu)      Join Date: May 2004       06-26-2008, 3:00 PM Reply
Mike, those JL amps pull a ton of current. The regulated power supply in them amplify the problem ( They still put out same power regadless of voltage input) Do the math in ohms law.
How long are your wire runs? from amplifier to fuse?
Do you have acess to amp meter?
All else fails run to your local welding shop and pick up some bigger cable.
Old     (acurtis_ttu)      Join Date: May 2004       06-26-2008, 3:02 PM Reply
OR fuse each amp seperately.
My last boat I had 5 amps and had 5 circuit breakers ( one for each amp)
Old     (seaswirlmike)      Join Date: Nov 2003       06-26-2008, 4:48 PM Reply
I do have access to an amp meter and I've had it on the cable before. the most I've seen it pull was 243amps.
the run from the fuse to the distro which divides into the amp's is probably 12'. I could possibly shorten it by 3-4' but it wouldn't be as clean so I was trying to avoid that but maybe its gonna have to happen
Old     (acurtis_ttu)      Join Date: May 2004       06-26-2008, 7:34 PM Reply
You can find calculators on the net that tell you max current draw based on guage wire. If you run is really 12 feet 0 guage is probably not large enough. IS the cable true 0 guage....some cables claim 0 but have a ton of insualtion and are really 2 guage. If your wire will be hidden welding cable is cheap.
Old     (jrhurst)      Join Date: Mar 2006       06-27-2008, 7:46 AM Reply
May be best to just run seperate power cables and fuses or breakers . Stay away from the stinger ones , we have had alot of em die .
