just keep in mind for the oil level, when you drop the boat in the water, the oil level can change. When its sitting on the trailer it can read higher if its sitting at a certain angle, and then once in the water, the oil level could recede towards the back of the pan and give a different reading. Also, when the oil pressure light comes on, do not turn the engine back on. Wether its the guage or not, you don't know. Checking the oil level wont tell you much because you could have full oil, but pump failure, which will cause the motor to go bye bye. Just stuff to keep in mind, but yeah take it to the dealer. its brand new.
