You can't really adjust the KDW to help that. To refine waht GD said, the problem occurs because the paddle wheel doesn't properly read the boat's true speed in the turn. One possible explanation is that when the boat leans in the turn the water is deflected differently across the paddle wheel. It is possible that water from the keel gets deflected across the paddle wheel, making the Perfect Pass think you are going too fast and it slows the boat down. On the other hand, if water is deflected away from the paddle wheel it thinks you are going too slow and the boat speeds up to compensate. The first boat I had with Perfect Pass (Air Nautique) didn't suffer from this at all. My current boat, a Super Air Nautique, speeds up on right hand turns and slows down on left hand turns. Rod
