Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 19, 2005
Old    team909            05-23-2005, 10:46 AM Reply
im trying to learn the railey(not sure how to spell it) any advice or tips on how to exicute this trick the best
thanks
team909
Old     (mhsb1029)      Join Date: Jan 2004       05-23-2005, 10:56 AM Reply
Raley
This is taken from the WW website:
Backside Air Raley
Description: Starting heelside, rider goes into air and raises board above the body (pushing the board up - inverted)
Category: Advanced
Point Value: 1250
Tip on performing this trick: Joel Goertz from Kelowna, BC,Canada says; "Like most big tricks, the Raley requires a specific approach. The approach to this trick is absolutely crucial to its execution. Speed is key. Edge out as far as you can on your toes to set up for the backside/heelside approach. Use your progressive cut but build it quickly and increasing it as you get closer to the wake. As you get closer to the wake, start dropping your butt lower than normal and keeping your back straight. Stay low. Edge all the way through the wake and you will feel the lift on the board. Let it go. When you've reached the peak of your extension, start bringing the handle down towards your knees and bring your feet back underneath you for the landing. This is when you'll discover whether or not you got a good cut to the wake...Plan for a few painful failures. There is a huge psychological aspect of this trick and overcoming it is half the battle. The key is all or nothing. Good luck
Old    team909            05-23-2005, 11:11 AM Reply
thanks i think im ready for some faceplants so ill have to try the keep low approach p.s are they possible behind a I.O.
