I couldn't tell from your post where the 500 lbs was. Place it in the back and on whichever side you feel more comfortable on, then put all your riders on that same side. Your optimum speed should be around 10-11 mph, much more and the wake gets smaller...much less and you don't have enough forward movement to plane the board. Now you best position to keep it going without the rope is to be somewhere between 1.5 to 4 feet behind the swim platform. Don't think of getting pushed from behind like you would see in real surfing, instead...really just try to drive that inside rail of the board right into the wake...lean forward to go faster...stomp the back if you go shooting toward the swim step too fast. Its all about tiny movements. Also, if possible where you ride, have the driver hook you into a shallow turn to the inside.
