Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through November 14, 2005
Old    srxboy            10-25-2005, 6:11 PM Reply
I noticed my bilage pump running a lot and noticed water leaking in threw my shaft seal. I have never repacked one before and was looking for any tips and also what size packing do I get? Thanks
Old     (mook)      Join Date: Aug 2005       10-25-2005, 8:01 PM Reply
Brandon,
I contacted Malibu and they told me I needed a 3/16" packing for my VLX. So I bought the GFO, Gore-Tex "dripless" packing from SKIDIM.com and replaced it a couple of weeks ago.
I have a V-drive, so it was difficult to get to the gland nut, but after scraping the old packing with a small screwdriver inside the gland nut, it finally came out after 15-20 minutes. (believe me, that stuff gets crammed up there....)
After getting all of the old packing out, it was simple. I cut the new packing to the length that would fit around the shaft and butt up the ends when wrapped around. I stuffed each piece of the new packing into the nut and hand-tightened down each one before stuffing the next. I put three pieces in total and then tighted the gland nut all the way down to the stop, and then secured it with the tightening nut, and it was done. Very happy that I did it myself as the total job cost me around $13 and I had heard people were paying their mechanics $400 and $500 to do a V-drive. (which is high even to a dealer)
If you have a DD, I would definitely go for it. If a V-drive, you better have some patience and long arms to get under there to get that old packing out. My shaft does not leak at all now (it used to flow like yours), and the shaft does not get hot after driving a couple sets. I believe the shaft is supposed to drip when running, but not when idling, so I have been watching it to see if it will start to drip slowly when in gear.
Hope that helps.
Good Luck!!
Mook
(Message edited by mook on October 25, 2005)
Old    srxboy            10-25-2005, 9:05 PM Reply
mook thanks for the advice! I have a 98 supra comp, it is dd so I think I will give it a shot. Any one know what size to use? Thanks again!
Old     (jon4pres)      Join Date: May 2004       10-26-2005, 6:52 AM Reply
I did mine. You need to be careful when digging the old stuff out. You dont want to scratch or score the shaft. I had a DD and i bet it took me all of 15 min. I also used the GFO. I tried to make mine leak a little once I got to the lake so I started loosening the nut. By the time i got it to leak I had completely removed the nut. After tightening it back up I just checked it after every set that day to make sure it was running cool.
Easy DIY job
