Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through November 14, 2005
Old     (pittsy)      Join Date: Apr 2004       10-18-2005, 6:49 PM Reply
Is the Orion 1200D a good amp to power 2 10" Kicker L7s??
Old     (brick)      Join Date: Nov 2003       10-19-2005, 8:17 AM Reply
I'm not an audio expert, but I would say no. I'm currently using the Orion 1200D for a single JL12w6, which provides 725W at 2 ohms. If you were to wire the L7s in parallel, this would only give you a little over 300W to each sub at 2 ohms (feasible, but not optimal). I would lean toward the Orion 2500D, which can run 850W at 2 ohms to each sub.
Old     (airrantz)      Join Date: Jun 2004       10-19-2005, 8:47 AM Reply
Matt, if the L7s are 4ohm DVC then that amp will be good. If you wire 2 4ohm DVC subs in parallel you will be running at 1ohm. http://mobile.jlaudio.com/support_pages.php?page_id=161 This will give you 1200 watts of power to both subs.
