Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through November 14, 2005
Old     (shelstad)      Join Date: Oct 2005       10-03-2005, 5:18 PM Reply
Looking to buy some sac's and hoping to get some opinions.
Any imput will be appreciated...
What qualities should I be looking for in buying weight 4 my boat? PRO's CON'S
Do you like fly high or launch pad Why? Why Not?
Old     (zacky)      Join Date: Apr 2003       10-03-2005, 6:49 PM Reply
My buddy has a couple of those Launch Pad 440 square sacs. What a pain in the a$$ to get those things completely empty. It is like there is some secret compartment in those sacs that always wants to retain about 50lbs of water...
Old     (texastbird)      Join Date: May 2003       10-03-2005, 7:22 PM Reply
You can squeeze the water out of those sacs, or just hold them up by one end and let the water drain out of the internal compartment. I agree, it is a PITA, but you can get the water out.
Old     (madchild1)      Join Date: Mar 2005       10-04-2005, 10:08 AM Reply
go pro-x. the quality is unrivaled. i have the 680# seat sack and have no complaints. also, you can get them custom built in any size/shape you desire.
Old     (cyclonecj)      Join Date: Jul 2001       10-05-2005, 4:27 PM Reply
Pro X series. You get a quick disconnect fitting with them that uses a standard 3/4" thread. You don't need the fancy pump. NO more blue thingy!
Old     (rich_g)      Join Date: May 2003       10-05-2005, 4:36 PM Reply
I have had both, recently upgraded the front sac to Pro-X. It's great. I like the fact that it drains completely.
I had the 440 Launch Pad, and it was a pain to get all the water out. I talked to the Launch Pad guy, and he explained that the original design has a baffle system that could cause a problem. He said they have fixed that design issue, so if you need a rectangular 440 to fit a certain space, the new one is probably OK.
Old     (talltigeguy)      Join Date: Sep 2003       10-05-2005, 7:43 PM Reply
Another vote for Pro-X.
Old     (buzz_grande)      Join Date: Mar 2004       10-05-2005, 11:33 PM Reply
And another vote for Pro-X. Super-sturdy, and the valves are great!
Old    e420x            10-06-2005, 5:55 AM Reply
Anyone using the v-drive sacs? I do not have a v-drive but figured they would be good for either side of the engine ?
Old     (gdog)      Join Date: Jun 2005       10-10-2005, 11:00 AM Reply
i use 2 pro-x 400lbs v-drive sacs for my 04 vlx and they work great. i have them hooked up to the stock ballast system. no probs at all
Old     (juice75)      Join Date: Jul 2004       10-13-2005, 4:03 PM Reply
I have the Pro-X v-drive sacs, and they rock! I started with the Launch Pad 440lbs, then switched to the Pro-X. I used them in my old Supra Comp direct drive on each side of the engine, and they worked perfectly. I just upgraded to a '99 Malibu VLX, and can't wait to put them in the rear compartments.
Old     (gene3x)      Join Date: Apr 2005 Location: Dallas , TX       10-19-2005, 1:32 PM Reply
How did you hook them up to the stock ballast system? Anything special needed?
Old     (rich_g)      Join Date: May 2003       10-19-2005, 2:12 PM Reply
Gene, the Pro-X comes with its own plastic fittings, including 2 with a 3/4" barbed hose attachment. Just slide the hose on and clamp it. If you are using 1" hose you will need a special fitting.
Old    d_fresh            10-19-2005, 5:15 PM Reply
Talked to the guy's at B.F.I. For '06 they will have a fat seat and a under the bow seating sack in the Pro-X series.
Old     (ruffneckrider)      Join Date: Jan 2005       10-19-2005, 8:24 PM Reply
I have a pair of brand new Pro X Series wagde sacks for sale if anyone is interested 150.00 shiped! and yes they rock I run the wage sacks in my '04 SAN
