individual pieces, that way, when you tighten down on it with the hollow nut, it packs tight instead of bunching. Cut one as a guide, so it fits around the shaft perfectly. Cut as many others as you need to fill your packing hollow. When you insert them, make sure the ends are not in a line, they should be opposite each other. Hope this helps.
