05-06-2005, 8:57 PM
I have a Malibu 2004 with a Mansoon engine. It's a little loud. I saw a down turn exhaust extension that attaches to the back. Any info would be appreciated.
05-06-2005, 11:05 PM
05-07-2005, 3:43 PM
with the boatpipes, isnt there somewhat of a drag or an interference in the control of the boat from the pipe? It looks like it would act as an additional fin.
05-07-2005, 5:20 PM
I have one on my Centurion Eclipse V Drive and I love it. Does not effect performance or handling. Reverse "walking" is a little effected on my boat but not to the point of being a problem. At wakeboarding/wakesurfing speeds the noise is greatly reduced. Still has a nice sound at WOT. No exhaust fumes when wakesurfing, is the main reason that I got one.
05-07-2005, 8:08 PM
You didn't say which Malibu you have, but I'm guessing it's a direct drive because the v-drive's come with mufflers. You can install Silent Rider mufflers (which are a factory option) to decrease sound levels substantially. The Monsoon is much quieter with them installed, and you won't loose much power at all.
05-07-2005, 9:17 PM
I have a 2004 ddrive Malibu w/ Monsoon 340 engine. How much would the silent ride mufflers cost? Can I install them myself?
05-08-2005, 5:34 PM
I have the boatpipe system and it has been working great, way less noise from the motor both inside and outside the boat and you can now surf for an hour with no CO poisoning and no exhaust fumes while idling through the 5 mph zones either.
05-09-2005, 7:53 AM
Gordon - that's a sweet setup. Does the FAE attach to the bottom of the swim platform? If so, how does it attach? Did you have to drill holes in your platform? I'm trying to decide between the FAE system and Silent Rider Mufflers. The mufflers are a little cheaper, but the CO2 reduction is appealing.
05-09-2005, 9:35 AM
Kraig, On my model, it is attached to the swim platform brackets, not the swim platform itself. Most of the other installation photos I've seen it is attached to the platform. You can see detailed installation instructions here: http://www.boatpipes.com/Installation.jsp
05-09-2005, 10:40 AM
Which would quite the boat more? Switching to Silent Rider or FAE
05-09-2005, 1:28 PM
David: If you want more info on Silent Riders, you might check out www.themalibucrew.com, that's where most of the Malibu owners hang out. FYI on the boat pipes: If you have a wedge on your BU, I don't think it will work.
05-10-2005, 8:27 PM
A really wierd thing, when we went from a Tige 22V to a 24V having the exact same engine with the exact same exhaust part numbers, the engine sound level in the boat went way down. I personally think something has changed in the Marine Power Vortec exhaust but it's proven it has not. Could being a little farther away from the exhust be that noticable? Both engine sound levels are fine for me, but adding a way to lower the engine noise is always good for us old farts. Has anyone added one of these exhausts to a Tige?
05-11-2005, 5:59 PM
This post is from Larry Mann, inventor of Fresh Air Exhaust (FAE), also called Boat Pipes. Our customers have said that there was a substantial reduction in noise with FAE and that boat handling was not affected. One Tige customer said FAE was "transparent". The Centers for Disease Control, in a study for the US Coast Guard, claim up to 90% reduction in Carbon Monoxide levels. Mounting is of course to the exhaust outlets, and to either the swim platform or the transom. There is virtually no loss in engine performance. The Malibu wedge will still work, but it won't swing. We replace the Wedge bolts with quick release pins so the Wedge can be either in the up or the down position. FAE fits on all inboard boats we have checked. We are happy to answer any questions you may have.
05-12-2005, 11:05 AM
So you have to physically remove and replace the wedge when you want it deployed? How many of those will end up on the bottom of the lake?
