Good suggestions on the oil, fuels and fogging.
Sorry, Mark. I have to disagree with you on the antifreeze.
I don't know how cold it gets in NJ, David (I KNOW St. Paul is cold, Mark
) but here in Colorado, it gets well below zero in the winter. I had a 4.3L V6 in my first boat, I used RV antifreeze one winter and it gelled, expanded and blew the head gaskets out.
I have tested the most recent formulations (purple and pink) of RV antifreeze this year in my freezer (about zero Farenheit). I put a couple of ounces (undiluted) of each in old Arrowhead bottles and put it in the freezer. The RV AF froze solid after just one hour. Try it for yourself, it only takes an hour and 2 bucks.
Ask the boat mechanics what THEY use, if they use antifreeze at all. Most of them just drain the block and call it good.
You can use auto-grade antifreez, for protection to sub-zero temps if you are careful, but only if the boat is out of the water, and stays there for the winter.
Be careful with it, and contain spills. It will kill or maim animals that drink it. It tastes sweet to them.
DON"T use the boat in the spring until you have drained the block and flushed the engine. Again, contain spills.
Good luck.
YMMV.
(Message edited by spoon on October 17, 2004)
