Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 08, 2008
Old     (jimrowe)      Join Date: Mar 2008       05-10-2008, 6:16 AM Reply
I have a 89 supra. I put the boat back in the water and it was fine a idle, then drove for a 30 seconds and it shut off. Then wouldn't crank back up, but after a minute or so crank right back up and I let it idle. Then went to take off again and cut out. Any help??
Old     (bobenglish)      Join Date: Mar 2008       05-10-2008, 7:01 AM Reply
Many potential causes. I would look at the fuel pump first. Any gauges have abnormal readings?
Old     (psudy)      Join Date: Dec 2003       05-10-2008, 7:19 AM Reply
Check the fuel filter for water.
Old     (h20jnky)      Join Date: Mar 2003       05-10-2008, 9:23 AM Reply
check all your battery connections..
Old     (bigkitch)      Join Date: Apr 2008       05-10-2008, 9:23 AM Reply
when it shuts off do you loose all power? or what exactly happens
Old     (jimrowe)      Join Date: Mar 2008       05-10-2008, 11:12 AM Reply
I was thinking about the battery connections as well. Yeah graham it shuts down, then I try to crank it and its trying to turn over but doesn't. Then after a few minutes it will crank back up. Its seems like it could be a problem in the ignition somewhere.
(Message edited by jimrowe on May 10, 2008)
Old     (westsidarider)      Join Date: Feb 2003       05-10-2008, 7:41 PM Reply
if it actually is cranking then it wouldnt be a battery prob cuz obviously it has the power to crank. i would lean more toward the plugs or rotor cap as far as electrical. sounds more life a fuel problem to me though.
Old     (h20jnky)      Join Date: Mar 2003       05-10-2008, 8:01 PM Reply
carb cleaner.. fast, easy and cheap..
Old     (rallyart)      Join Date: Nov 2006       05-10-2008, 9:07 PM Reply
Jimmy, it could be an electrical power draw that kicks a circuit breaker. As soon as the circuit breaker cools back off it resets itself.
This happened to a friend's boat and it was the breaker shutoff attached to the engine on his Mastercraft. The power draw was from a failed amplifier on his stereo and it didn't matter if the stereo was on or not.
Old     (greg2)      Join Date: May 2002       05-10-2008, 9:49 PM Reply
Fuel filter??
