Old     (suthaforce)      Join Date: Feb 2004       07-07-2009, 6:48 AM Reply
This weekend we were out, and I noticed when I would turn on my blower or bilge it would cut out my radio as if my battery were getting weak, but it is not and reads 100%. Eventually I lost everything on my dash, and found a 10amp fuse was blown, I replaced and when I turned on the bilge it blow immediatly again, so replaced it with a 15, everything now works, but when I turn on the bilge it blows out the little button breaker under the switch. Do I have a short in my bilge somewhere or is it possibly burnt up?
This is an 05 moomba LSV.
Old     (madriding1)      Join Date: Sep 2008       07-07-2009, 7:31 AM Reply
Hey Dave... I have an 08 LSV and my bilge was getting plugged up from carpet fiber and blowing the fuse. There is a screen filter in the pump, try seeing if that is plugged up causing the fuse to blow.
Old     (suthaforce)      Join Date: Feb 2004       07-07-2009, 7:07 PM Reply
Took a closer look tonight, and when I flipped the switch for the first time it ran the pump for a second then blew the button breaker. I reset it now my bilge switch will stay on without tripping the breaker but I get nothing out of the pump. Is there another screen inside it after you pull the bottom cage part off? That did not seem to be clogged. I would hate to go buying a new pump when it could be something else.
Old     (madriding1)      Join Date: Sep 2008       07-08-2009, 9:13 AM Reply
Dave, I looked at mine last night and just saw the one screen.
Old     (suthaforce)      Join Date: Feb 2004       07-10-2009, 8:38 AM Reply
Thanks for your help Mike. The pump just ended up being shot. I upgraded to the 750 GPH, but had to cut to the wires and use butt connectors instead of the plug, so you will probably see a pic of me in the please use your blower thread
Old     (denverd1)      Join Date: May 2004 Location: Tyler       07-10-2009, 9:21 AM Reply
Put silicone or marine sealant on the ends of your connectors.
Old     (suthaforce)      Join Date: Feb 2004       07-10-2009, 1:37 PM Reply
I used butt connectors that you can melt the ends with a heat gun to seal it, so they should be pretty good.
