Old     (brett33)      Join Date: Apr 2011       07-21-2011, 9:36 AM Reply
anybody have pictures/ advice of how they lit their 485s up?
im wanting to do the speakers and horns. i have rings for the 8s already but as far as light strip placement im lost..
thanks
Old     (mikeski)      Join Date: Aug 2003       07-21-2011, 11:50 PM Reply
like this...
Old     (david_e_m)      Join Date: Jul 2008       07-22-2011, 5:56 AM Reply
Just curious...but how's the wake behind that Maytag?
Old     (992envy)      Join Date: Jul 2011       07-22-2011, 9:01 AM Reply
Very nice Mikeski, do you have pictures of how and where you ran power to the rings? Also what kind of led lighting/ material is that?
Old     (mikeski)      Join Date: Aug 2003       07-22-2011, 9:51 PM Reply
Wake is good as long as the tub is full of ballast...
drilled a hole next to the speaker and wired it to the two spare poles on the speaker plug. The material is standard LED tape, available almost everywhere on the internet.
Old     (brett33)      Join Date: Apr 2011       07-25-2011, 10:57 AM Reply
thanks mike, where did you pick those rings up, or did you make them? mine dont have the slot for the strip to go down into. i assume ill still need to position the lights inward, just have to glue them.
Old     (brett33)      Join Date: Apr 2011       08-16-2011, 9:14 AM Reply
im coming back to this thread because i need some advice. Mike, says he "drilled a hole next to the speaker and wired it to the two spare poles on the speaker plug." But wouldn't that mean that his tower LEDs will stay on when the boat comes on? I dont want to do this. Does anyone have any other advice for wiring a pair of 485 speaker rings to a toggle?
Old     (wetsounds1)      Join Date: Jan 2006       08-16-2011, 9:30 AM Reply
nauti 210. you will drill a small hole in the frame of the driver and into the housing to push the led wire into. Then wire it to the 2+ and 2- on the nuetrik speaker plug. So you will need 4 conductor wire to each speaker if using single color led. pair of wire for the speaker and pair for the led's. If using RGB led's you need 6 conductor. 2 for the speaker and 4 for the rgb led's.
run the wire down the tower and make sure you fuse it! Then run it to a switch on the dash. A toggle is what we use. I have one for the tower led's, one for inboats, one for the amp rack led's etc...
Tim
Wet Sounds
Old     (brett33)      Join Date: Apr 2011       08-16-2011, 10:01 AM Reply
Thanks Tim!
So let me get this straight...
I am running single color LEDs. so basically, the + and - wires from each ring will be wired into the + and - spare ports on the quick connect Nuetrik (2 positives and 2 negatives since there are 2 speakers in each pod).Then coming out of those same ports on the Nuetrik will be the + and - wires that will run to a fuse (im assuming both pods will be fused separately or can they be linked with 1 fuse?) then into the toggle.
Is this correct?
Also, do you have a preference as to the direction the LED strips should be mounted? Mike shows his with the LEDs facing inward. With frosted rings is it ideal to mount the LEDs outward like my in-boat speakers are?
Old     (mikeski)      Join Date: Aug 2003       08-16-2011, 11:41 PM Reply
in facing or out depends on the depth of the ring and color of your speaker. I prefer mine facing in after trying it both ways. If your rings are not as deep or if you have black your results will differ.
The rings were CNCd at a machine shop to my dimensions. I would do it differently if I did it again today. I have about $300 into my rings.
