Old     (unclejessie)      Join Date: Jan 2004       06-28-2010, 1:01 PM Reply
I have a 4 channel amp that I have configured as follows;
ch1: 2 6x9 in parallel (2 ohm load total)
ch2: 2 6x9 in parallel (2 ohm load total)
ch3 and ch4 bridged to a sub.
Should I wire the dual coil sub in parallel for a 2 ohm load or series for an 8 ohm load? In my head I see the 2 ohm of a dual coil sub in paralle as drawing more current, but does this translate into better sound? I also see an 8 ohm load being closer to a balanced amp (2, 2 ohms on one side and an 8 ohm on the other). Maybe a balanced load doesn't mean anything?
-Uj
Old     (johnny_jr)      Join Date: Mar 2006       06-28-2010, 1:22 PM Reply
Most 4 ch amps will not run at lower than 4 ohms bridged so in your case you can only wire at 8 ohms to keep the amp from shutting down. Check the amp specs, if it will run at 2 ohms bridged (Ch3+4) than you can run the sub at 2 ohms.
Note running at 8 ohms will force the amp to produce only half of its RMS power rating.
Old     (unclejessie)      Join Date: Jan 2004       06-28-2010, 1:26 PM Reply
Interesting.... I have it wired as 2 ohm now and this weekend I was having issues with the amp shutting down... Why have dual coil subs if we cannot connect them to a bridged amp? Is briding a bad idea?
Old     (unclejessie)      Join Date: Jan 2004       06-28-2010, 1:33 PM Reply
I have an Eclipse 3422 and the manual I found online says it can handle a 2 ohm load. It might have been cutting out for other reasons, like the gain was set too high and it just overheated.
Old     (johnny_jr)      Join Date: Mar 2006       06-28-2010, 1:49 PM Reply
Give me a call Mark and I'll talk you through it.
408-230-3093
Old     (chpthril)      Join Date: Oct 2007       06-28-2010, 1:59 PM Reply
Most sub manufactures offer 2 and 4 ohm DVC configurations. For bridging, a 2 Ohm DVC is the way to go with most amps.
Old     (unclejessie)      Join Date: Jan 2004       06-28-2010, 1:59 PM Reply
Hey Jonny. Thx, I will give you a buzz after work. i just read your profile... haha, now I know who you are!
