Need input: I was using the fake a lake at home, and everything was normal, except after 10 or 15 seconds no water was coming out the back. I tried this 3 or four times, and did not let the boat run past 10 seconds each time. The engine was warm but not hot. I rechecked everything over, and everything was hooked up right, and I replaced the plunger to make sure. I raised the nose of the boat, and still nothing happened. Like the third time I heard a squeak for a second or two, and I turned the boat off. Had this ever happened to you? I dont drive through anything that would have clogged the intake. Is the impeller faulty? I am just unsure what is happening. Thanks for the imput. Boat is a 89 Malibu Sunsetter with 350 Merc.
