Old     (truebeachbum)      Join Date: Oct 2006       06-13-2007, 12:39 PM Reply
does anybody have any pics of how they hooked them up.
My stereo keeps cutting out when i play it for a couple of hours, all the way up would fans help this.
Old     (acurtis_ttu)      Join Date: May 2004       06-13-2007, 12:56 PM Reply
Trace, I'm going thru a similar issue. It could be a number of things. I haev narrowed it down to either being a bad amp or the brand of amp I have just run that hot. this is after numerous diagnostics with the manufactuer of the amp. I haev some fan lying around so I'm going to add them. Very easy to wire. you'll need a relay. hook the remote wire up to the relay so when your stereo powers on the amp fans turn on. what amps do you have
Old     (truebeachbum)      Join Date: Oct 2006       06-13-2007, 1:36 PM Reply
2 kenwood stock 1 kicker running a type r
Old     (acurtis_ttu)      Join Date: May 2004       06-13-2007, 1:54 PM Reply
Don't the stock kenwood already have built in fans?
I knwo the kicker has buitl in fans.
Something doesn't sound right. You asked this question ealier in a post, did you check everything that was listed?
Old     (truebeachbum)      Join Date: Oct 2006       06-13-2007, 3:04 PM Reply
is the one on the kicker amp visible n the kenwood amps dont have fans and were i ride its like 100 degrees then all that is i a compartment with no venilation
Old     (bob)      Join Date: Feb 2001       06-17-2007, 10:20 PM Reply
Chase I just added a 1" wide aluminum strip across the face with 1-2 small computer fans attached but you may need more then that due to your high ambient temps. What about a small bilge blower with a 3" hose aiming at the amp area and grabbing outside air for the cooling? A buddy with an SSV did this and he mounted the blower at the area beside the passenger next to the driver where there was a gap thru to the storage area.
Old     (hudd007)      Join Date: May 2006       06-17-2007, 10:35 PM Reply
My stereo guy added a drum type fan right above the amp. Its close to the wall so its not going to get in the way.
Old     (bmh2208)      Join Date: Apr 2004       06-19-2007, 9:44 AM Reply
This is what I have done so far. I still have to make a bracket to blow air directly onto the amps
They will be hooked up to a relay that gets switched on when the remote signal fires from the head unit.
Old     (wake1823)      Join Date: Dec 2005       06-19-2007, 10:18 AM Reply
Looks good Brandon, please post more pictures when your finihsed.
Old     (garret_s)      Join Date: Apr 2006       06-19-2007, 10:22 AM Reply
If I were you, I would look for some super high CFM fans...not all computer fans are made alike.
Old     (bmh2208)      Join Date: Apr 2004       06-19-2007, 10:59 AM Reply
I'll post some more tonight in my thread on pn. I still have to finish wiring up the bulkhead on the fiberglass where the connector goes.
The fans that I am using are 120mm x 38mm 72cfm fans that are completly sealed and waterproof. This things can actually run under water.
(Message edited by bmh2208 on June 19, 2007)
Old    bocephus            06-19-2007, 11:32 AM Reply
I use these for cooling...
http://www.frozencpu.com/products/2571/fan-88/FrozenCPU_172x150mm_Fan_b265_CFMb.html?tl=g36c15s7 3
They are pretty expensive, large and kind of noisy, but they move 265 CFM which helps to cool things down in tight spaces!
