Bevan,
Its hard to believe that you torched every speaker on the boat without realizing it. But all it takes is a couple of blown speakers to ruin the entire sound. So isolate various speakers with the balance or fade. Once you have isolated a bad speaker or channel you can also rotate RCAs and speaker wiring in order to determine if the problem is upstream or downstream in the signal path. But always clearly label every wire before making any changes so that you leave bread crumbs.
Yes an inexpensive multimeter is an essential tool. With that and a couple of jumpers you can diagnose most any problem.
After winter/summerazation grounds often get left off. The system can derive a ground from alternate interconnecting sources that will allow operation but only up to a certain current level.
Resting voltage on a healthy and fully charged battery should be 12.6 to 12.7 volts. Everything should play fine at 12 volts. Around 11 volts and below can allow the system to play but it can start misbehaving.
If you are going to remove any amplifier primary supply cables you will want to disconnect the battery first via the switch, breaker, fuse or terminal. If you are making any other disconnects like remote turn-on leads, RCAs or speaker connections then you only need to make sure that the source unit is turned off first.
If you are getting confused then you might draw up two illustrations, one of the signal path and one of the power path of your system. This will keep things straight and uncluttered.
Other than that you are just going to have to roll up your sleeves and invest the effort. Check the voltage first, all physical connections second, and then start the process of isolation and elimination.
David
Earmark Marine
