I just drained my 08 Monsoon today for the first time. There's a 1/2" nut that holds a the knock sensor on and then the plug is gonna need a 1" wrench or socket if I remember correctly. The 1/2" nut was so tight on the one side that the drain plug came out attached to everything (really not a problem, less work). On the other side, I removed the 1/2" nut, then the plug. The housing the sensor plug goes into is almost like a really thick washer. As long as you don't pull, wiggle, or try to unclip the the plastic plug portion of the sensor the wrong way, it should be hard to do any damage to the sensor. Hope this helps.
