06-28-2007, 9:56 AM
I WAS CURIOUS I RIDE A 07 SHANE 136 AND I AM 6'1 THINKING ABOUT CHANGING MY STANCE ALL THE WAY OUT INSTEAD OF 1 IN, FIGURED IT MIGHT HELP KEEPING MY KNEES BENT WHEN IN THE AIR FOR BETTER STYLE, NOT SO STRAIGHT LEGGED, ANYBODY NOTICE HOW LONG AND WIDE JD WEBB'S STANCE IS ?
06-28-2007, 9:58 AM
All the way out!
06-28-2007, 9:59 AM
All the way out here too.
06-28-2007, 10:00 AM
06-28-2007, 10:02 AM
I'm 5'10" and I ride a shane 140 all the way out, which is 25 inches.
06-28-2007, 10:03 AM
Hey Boris where is your profile pic taken, that is sick.
06-28-2007, 10:08 AM
-Dombai snowcamp 2007
I am 5'8" and ride a 135 3ds all the way out. you might actually want to check out the 140 for a guy of your height. just a thought.
all the way our on a 143 Player. In the 25-26 range.
06-28-2007, 10:11 AM
all the way out.
06-28-2007, 10:17 AM
I am 5'5' and ride a 142 watson and ride 1 in from all the way out.
I ride all the way in! Old school steez!!! J/k Im all the way out, both feet angle out.
06-28-2007, 10:18 AM
Ssup AK! -James, if you freestyle snowboarder, i think you need to put your bindings on the wakeboard on the same wide. That was really comfy for you. Fo sho.
06-28-2007, 10:27 AM
all the way in, pidgeon toed. Makes for really great edge control.
06-28-2007, 10:37 AM
All the way out...just a hair ducked.
06-28-2007, 10:38 AM
JD is also like 5'6...not quite 6'1
06-28-2007, 10:41 AM
quote:I'm 5'10" and I ride a shane 140 all the way out, which is 25 inches.
Same here. -Steve
06-28-2007, 10:45 AM
all the way out, both feet ducked equally quite a bit.
06-28-2007, 10:58 AM
i never ride all the way..my balance is much better 1 in..i have actually landed more tricks 2 in than all the way out..
06-28-2007, 10:59 AM
i'm 5'9 and ride the shane 140 all the way out.
06-28-2007, 11:08 AM
6-1/200, 07 trip 142, and one in on both sides. Easier on the knees.
06-28-2007, 11:10 AM
All the way out on my Absolute 135.
06-28-2007, 12:45 PM
all the way out for sure
06-28-2007, 12:57 PM
1 away from all the way out, ducked a bit... not sure on the inches. (its on an 07 Murray 142) I am 6'2" and 190 lbs
06-28-2007, 1:01 PM
5'9" on the Watson 138 and all the way out.
06-28-2007, 1:17 PM
Joe Umali: "Slutty Wide"
06-28-2007, 1:33 PM
I'm also 5'9" but ride one in on an 05 Ricky G.
06-28-2007, 1:48 PM
All the way out. 136 Shane. I'm 5-10/180
06-28-2007, 1:57 PM
1 in and about 15 degrees ducked on both. Use to be all the way out but I found this is a little easier on the knees. I am 5'8"
06-28-2007, 2:30 PM
im 6 ft riding 06 marius 134 all the way out. i have ridden up to a 140 all the way out its how i ride my snowboards also
06-28-2007, 2:35 PM
you need a bigger board charley. 134's too small if youre 6ft bro.
06-28-2007, 2:41 PM
i actually like it because it rides a lot bigger then it is. it bled onto my boats interior at shasta last week though so i need to get in touch with cwb because my dads pissed and if they replace it im gunna try and get the 140 because my dad hates riding it being hes just as tall as me but about 70lbs heavier
06-28-2007, 2:42 PM
All the way out, feet straight. Player 143
06-28-2007, 3:17 PM
I was all the way out for years and tried one in last week and loved it. Much easier to spin that way. So ..1 in on both feet a just a bit ducked.
06-28-2007, 3:29 PM
Im 5ft 6 , ride the LF team 139 all the way out
06-28-2007, 6:55 PM
all the way out
06-28-2007, 9:53 PM
All the way out is the way to go.....saves your knee's a bit and you can compress better coming down from big jumps.......I think it gives you more balance as well......alot of the pro's if not most all are riding all the way out too....no matter what weight or height they are....
06-29-2007, 6:09 AM
As wide as it goes.
06-29-2007, 6:25 AM
5"6' 145 lbs. here and ride the Shane one in from all the way out. Is it just me or have I noticed that the majority of wakeboarders are not tall.
06-29-2007, 4:12 PM
im about 5ft7 and i ride a 132 byerly all the way out wiht a pair of sphinx's
06-29-2007, 5:18 PM
1 in on a 140 marius...I tried all the way out two weeks ago and rode like crap as well as tearing my mcl and meniscus. everyone rides all the way out but I'm weary.
06-29-2007, 5:49 PM
if you ride all the way out you will have a lower center of gravity there for if you land a bit dodgy you have a better chance of landing that trick i ride all the way out and love it
06-29-2007, 7:03 PM
i ride all the way out with both bindings ducked at 8 degrees out.
06-29-2007, 9:23 PM
be sure to check the width on all the way out cuz i went to a bigger board and went all the way out and it was one inch wider than on my other board. Anyone noticed that around 5 years ago when stances were narrower there were far less pros with knee injuries?
06-29-2007, 11:02 PM
I ride the TRANSCEND 138 all the way out, with bindings ducked at around 12 degrees
06-30-2007, 5:33 AM
136 Premier, 6'1, 180, all the way out, just a lil' bitta duck in 'em.
07-02-2007, 10:51 AM
134 subjekt almost all the way out with some duck.
07-02-2007, 12:20 PM
Just moved mine all the way out a it ducked. I was preveously in 3 but I just got the board from a friend. It is way better all the way out for me. I feel more stable riding and w2w. It feels better switch too. I am still a novice but I thank you for the thread or else I would be stuck with the old setting.
