Outrage, I used to use a 16' Boston Montuak when I taught waterskiing at Club Med in Tahiti, Boston's make a pretty darn good tow platform. It's not too easy getting equipment in Tahiti so we U-bolted a 1.5" x 6' gas pipe to the seat with a ring welded to the top then ran a rope to the bow eye for support. Shortly after install we had to build bracing (rebuild) for the seatback. This was a very beat up boat so adding u-bolts was not a big issue. We also made a barefoot boom in similar fashion. Just wanted to let you know it works. We ran a 140hp Suzuki outboard, it screamed. You might want to run a sack up front to help distribute the weight more evenly to give the wake a little more ramp.
