I've ridden a bunch of different boards on rails.... and spend a lot of time hitting rails. Flex-boards are of course my fave (as most park riders would say).
Comparing flex boards on rails: You'll notice the difference in flex patterns long before you'd really notice the different rocker shapes. softer/stiffer tips or softer/stiffer belly, ect, ect.
If you had two flex boards with the same shape and flex you'd be hard pressed to note much between them just on rails...... you would notice it more just riding around on the water.
Personally I prefer a stiffish flex board with minimal drag.
Comparing stiff boards on rails: I'll take the two extremes. 2008/9 Ibex VS 2006/7 Murray. I have spent a bunch of time on both. And both really enjoyed, but on rails the ibex won by a landslide.
Just straight boardsliding with the murray on skinny rails would sometimes prove tricky as there was no flat spot in the belly to plant on. If you had momentum going in a certain direction you'd usually end up starting to slide off that way. Sometimes, this would get annoying.
Boards with major three stage are easier to get that sense of pressing because you have that tipping point where you go from the flat middle to the tip rocker. I think this feeling is great for people learning to hit rails properly before they get into ollieing straight on to the nose or tail. I think once you get past that point, rocker becomes less important and bottom features 'comes more of a concern.
My fave "traditional" stiff board is the Ronix Bill. Pretty featureless on the base so you can get up on the nose and tail without much getting in your way. Plus it also has a low drag rocker line.
So for me. Don't think you can compare a stiff board to a flex board when it comes to rails. Apple and Oranges.
But when looking at a board to hit the park with, wether its a three-stage or not isn't that important to me, as long as its not slow and draggy. The first things I look for are bottom features, edge design and template. Pretty much looking for things that will give me the performance I want without getting in the way.
