I need suggestions and wiring diagram to install a second battery for the sound system in a 2001 V210 Should I use a Perko switch or isolator (diode v silenoid)? Here's where I need the wiring diagram. I read somewhere when using an isolator the red wire going to the circut breaker should be removed and conected directly to the positive post on the starter battery? also the 90 amp fuse seperating the altenator lead from the starter silenoid, should it be removed?
