Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 23, 2005
Old    propayne            07-19-2005, 7:47 PM Reply
hello fellow wakeworlders. the tige i am riding on is currently having a steering problem. it went from steering real easy and smooth to where now it seems like you have to yank it as hard as possible to turn the wheel. the boat is a 21V 2004. any info is appreciated.
Old     (colorider)      Join Date: Jun 2001       07-19-2005, 8:16 PM Reply
replace the steering cable
Old     (mobv)      Join Date: Jun 2002       07-20-2005, 3:40 AM Reply
I had a bent rudder that caused similar problems. Andy is most likely correct about the cable but check the rudder.
Old     (whitlock87)      Join Date: Feb 2005       07-20-2005, 5:26 AM Reply
Take it back to Tige.
Tige’s come with a great warranties.
3 years on the engine and other mechanical stuff
5 years on vinyl
Lifetime on gages and hull.
But on another note, my 04 Tige has already had its cable replaced
Old     (lcky275)      Join Date: Jul 2002       07-20-2005, 8:14 AM Reply
replace the steering cable. Water will seep (sp?) into the outer sheath and corrode the cable inside making it very difficult to turn. If it's a 2004 it should still be covered by warranty.
I was told that after a day on the water make sure the bilge is dry and turn the wheel so that the steering cable is retracted all the way inside the housing. This will make the cable last longer
