Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through May 01, 2004
Old    lachlantait            04-12-2004, 3:21 AM Reply
im currently making a slider, the problem is i want to know a good width to height ratio, at the moment it will be 180cm across (simply b/coz ive already built this part) now for the height i was thinking maybe 120cm but just looking at that it seems maybe a bit top heavy. So just give me your opinion on that.
and next for all the smart maths people out there can someone please work out the trigonometry stuff (angles to cut the slope) for me for either/both 120cm or 110cm??
surely someone knows how to do the shizzle
Old     (eternalshadow)      Join Date: Nov 2001       04-13-2004, 11:18 AM Reply
Give it to them in feet and inches... not too many understand our cm stuff.
Old     (rootc)      Join Date: Aug 2002       04-13-2004, 11:29 AM Reply
lots of things to consider. Is your slider a floating slider? what type of floatation? How wide is the base? Base width would depend on the flotation device used. Hieght would depend on base width. When you say across do you mean 180cm long or wide?
Old    lachlantait            04-14-2004, 5:24 AM Reply
okay... my conversion is pretty dogde but here goes.
its 21 feet long
6 feet wide
4 feet high.
floating slider using refridgerator foam for the floatation.
will it be to top heavy at 4 feet or should i change it to 3'7"
i think thats pretty much correct
Old     (eternalshadow)      Join Date: Nov 2001       04-14-2004, 11:11 AM Reply
Your flotation base is 6 feet?
Old    lachlantait            04-16-2004, 4:32 AM Reply
180cm/30cm in a foot seems about right to me. why whats wrong with a 6 foot width?
Old    lachlantait            04-22-2004, 4:26 AM Reply
Jeff can you help me any further. does it all seem in proporsion, will it tip over
