Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 26, 2006
Old    troystubb            11-12-2006, 4:14 PM Reply
I have a 06 supra with a roswell tower. the back mounts for the tower seem to not be sitting flat against the hull is this normal?
Old     (truebeachbum)      Join Date: Oct 2006       11-12-2006, 5:42 PM Reply
mine fits fine
Old     (supra24ssv)      Join Date: Mar 2006       11-12-2006, 5:54 PM Reply
show us some pics, then we can help
Old    troystubb            11-12-2006, 7:24 PM Reply
hey here are some pics ( sorry they are really bad , the key its right under the back mount of the tower
Old    troystubb            11-12-2006, 7:33 PM Reply
Old     (supra24ssv)      Join Date: Mar 2006       11-12-2006, 7:38 PM Reply
is the rubber spacer still under it
Old     (supra24ssv)      Join Date: Mar 2006       11-12-2006, 7:39 PM Reply
my rubber spacer shifted slightly but did not come out, if this is the case w/ yours, you should be fine
Old    troystubb            11-12-2006, 7:44 PM Reply
no the rubber boot is still on it , but there is a 8th inch space under the boot
Old    troystubb            11-12-2006, 7:45 PM Reply
i can see the screw threads
Old     (dan_lee)      Join Date: Jan 2003       11-13-2006, 1:29 PM Reply
FYI the tower is made by Xtreme Tower Products. Roswell is OEM for the accesories. If this seems to be an issue you can loosen up the nuts on these, set it straight and tighten them down. You may have to remove a speaker in the rear depending on which model of boat this is on but it appears to be on a 24?
There is a nut underneath, probably a 2 person job.
Dan
Old     (supra24ssv)      Join Date: Mar 2006       11-13-2006, 3:03 PM Reply
it will be fine unless it comes out, if i was worried this winter i would have the dealer replace the rubber stops for you it should be under warranty
Old     (ryan27r)      Join Date: Oct 2006       11-13-2006, 4:19 PM Reply
Bring it to the dealer and tell them whats up and you want if fixxed problem solved
