Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through May 22, 2006
Old    matman            04-24-2006, 1:20 AM Reply
hey . ive been wakeboarding for a while now. most of the time when i do heelside wakejumps just before i land i drop the drop the rope. i dont know why and i cant stop. i do good jumps. does anyone have any ideas as to why?
thanx
Old     (bughunter)      Join Date: Nov 2001       04-24-2006, 1:34 AM Reply
This is funny... only because I've had the same problem for a long time.
I got past this by concentrating on pulling the handle in close and low during the time you are in the air.
Old     (pittsy)      Join Date: Apr 2004       04-24-2006, 3:47 AM Reply
when you hit the wake push the handle down and keep it close to your hip...this should help with your control
Old     (showtime)      Join Date: Nov 2005       04-24-2006, 5:56 AM Reply
when you jump --and in the air --are you using both hands or just your forward hand?
Old     (allen)      Join Date: Apr 2005       04-24-2006, 7:43 AM Reply
Duct tape..
Old     (bughunter)      Join Date: Nov 2001       04-24-2006, 10:18 AM Reply
hehe duct tape... The crew in the boat decided that that would be the only way to fix my 'problem'. Tie wraps were also mentioned.
Or calling it the end of my session and leave me bobbing in the water to make me think about it the next time...
Old     (scottyb)      Join Date: Sep 2002       04-24-2006, 10:26 AM Reply
Have you friends call you a pussy everytime you drop the rope and you will not drop it anymore. Worked for me!
Old     (jarrod)      Join Date: May 2003       04-24-2006, 10:28 AM Reply
Eddy...I can hear Craig now
Old    matman            04-24-2006, 2:46 PM Reply
yeah i jump with two hands. when im in the air i sometimes let go of one hand first .
Old     (acurtis_ttu)      Join Date: May 2004       04-24-2006, 2:49 PM Reply
Are you dropping the rope or is it getting pulled out of your hands? IF pulled out of yoru hands....you could be laying off yoru edge at the top of the wake. If so concentrate on holding your edge all the way thru the wake. Stay on edge like there is no wake in front of you.
Old     (wakeandsnow27)      Join Date: Jun 2004       04-24-2006, 3:32 PM Reply
just dont drop it. that will help you hold on to it.
Old    walt            04-24-2006, 4:34 PM Reply
I believe the proper term is dropping your purse.
Old     (jcv)      Join Date: Oct 2005       04-24-2006, 4:40 PM Reply
mathew,
huck yourself into the biggest, off-axis flip you can do, hold onto the handle with both hands all the way through, and land (crash) as awkwardly as possible. and then, when you realize the pain really wasn't all that bad, you should have no problem holding on. works every time
Old     (kraig)      Join Date: Dec 2002       04-24-2006, 4:53 PM Reply
I was thinking fuzzy handcuffs.....
Old     (audiopro74)      Join Date: Jun 2005       04-24-2006, 5:42 PM Reply
I had the same prob. What worked for me was just concentrating on keeping the handle into my hip and saying outloud as I charged in "Commit and stick it" over and over. Mind over matter.
Old     (lumpy9138)      Join Date: Mar 2004       04-24-2006, 6:41 PM Reply
As I am the resident "taco dropper" on my buddies boat, I found that I was getting freaked out when I would get pulled forward on the landing. Having taken some hard nose diggers, I started dropping the handle. Make sure you take a nice progressive cut towards the wake, even if you don't stand up at the wake, you will still clear it. Keep the handle down low and centered. Even if it feels like you are going to get pulled over, hang on for dear life. If you took a nice cut and concentrated on handle placement, you should ride away no problem.
Old     (thane_dogg)      Join Date: Jun 2002       04-24-2006, 7:01 PM Reply
this was the day I fixed my problem.
http://www.wakepics.com/view_single.php/Big-Crash_wakeboarding-news.html?medid=4657
That was over 3 years ago.
You could also punish yourself by doing the robot, as you sink down into the water after a perfect landing without the handle. That's what we do in my crew.
As you can tell from the vid above, I never do the robot.
Old     (jhilltn)      Join Date: Jul 2004       04-24-2006, 7:05 PM Reply
thane, we've adopted that rule here in TN from some guys from Bakersfield. Only addition is that if you ride away without the rope and don't do the robot, you get a drive by.
EDIT: to answer your question, i think your problem is between your legs
(Message edited by jhilltn on April 24, 2006)
Old     (garret_s)      Join Date: Apr 2006       04-24-2006, 11:04 PM Reply
mathew,
No matter how many times people call you a "pussy", its most likely not the problem. The best way to solve what you have described is to make sure your rope position is tight to your lead hip (try to make it touch) as you approach the wake. It will feel akward at first, but you will be 10X the rider for it.
Old    matman            04-26-2006, 3:09 AM Reply
thts good. im going out on the water so i'll try and hold the rope to my hip as much as possible. thanx!
Old    00wakesetter            04-26-2006, 11:36 AM Reply
You have no hope, without the rope!
