Old     (yodd_tost)      Join Date: Aug 2007       08-10-2010, 7:09 AM Reply
Anyone done it themselves? What is the best way to go about it? Or should I just take it to a detail shop and let them go to town? Thanks
Old     (tyler97217)      Join Date: Aug 2004       08-10-2010, 7:23 AM Reply
Pretty easy, but depends on the decal and how long it has been on. I have removed lots of them. Take a hair dryer or a head gun out there and heat it good and start peeling. Peel very slowly and keep the heat gun just in front of where you are peeling. Once you are done take some goo gone, acetone, or lacquer thinner on a rag and wife away the residue. That is it!
Old     (h20king)      Join Date: Dec 2009       08-10-2010, 7:27 AM Reply
what ^^^ he said
Old     (Jeff)      Join Date: May 2010       08-10-2010, 9:27 AM Reply
I've also had success with the hair dryer. You can usually get the stickers off of there in large chunks or whole letters this way. I've always used denatured alcohol as my first solvent to try on residual adhesives. If that doesn't cut it well then I go to mineral spirits or lighter fluid. After I remove the adhesive I wash with soap and water.
Old     (Jeff)      Join Date: May 2010       08-10-2010, 9:28 AM Reply
BTW, depending on the size of the graphics it will probably take you longer to bring it to the shop and then pick it up afterwards then it would have taken you to remove it yourself. Not to mention the money.
Old     (acurtis_ttu)      Join Date: May 2004       08-10-2010, 10:00 AM Reply
if you haev never done this before, it's much safer to use a haridryer. Heat guns can get really hot and haev the potential to do damage if not used correctly.
Old     (yodd_tost)      Join Date: Aug 2007       08-10-2010, 4:07 PM Reply
Thanks guys, 1hr all the decals off. just a couple burnt fingers
Old     (brucemac)      Join Date: Dec 2005       08-10-2010, 5:27 PM Reply
pics!?
Old     (yodd_tost)      Join Date: Aug 2007       08-10-2010, 9:17 PM Reply
here ya go
Old     (jacobs0222i)      Join Date: Sep 2008       08-10-2010, 9:38 PM Reply
Very nice. I need to do that to mine.
