Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through February 11, 2004
Old     (blabel)      Join Date: Jul 2001       12-24-2003, 11:05 AM Reply
Apparently if you leave the cap off, the lube will eventually dry up. Go finger.
Does anyone know what chemical is used for the zipper lube so I can go by some?
Old     (colorider)      Join Date: Jun 2001       12-24-2003, 12:46 PM Reply
Blabel, I have just used parafin wax. Available from your local candle. Works pretty good in a pinch, or head out to your surf shop and get some zipper lube.
Old    akman            12-24-2003, 1:30 PM Reply
So what you are saying is you have a "DRY" helmet....blahahahahahahaha
Old    airjunky123            12-24-2003, 3:22 PM Reply
Zip Slip, a silicone based lube. Use beeswax on the metal part of the zipper to make it smooth.
Old    wakeboard_iraq            12-25-2003, 1:01 PM Reply
My dry suit came with a little cube of wax -it does the trick
