03-08-2006, 5:44 AM
Boat goes in April 1st and I have neither. Was in the water until Oct. 15th last year in shorts and was fine but have the feeling the water is going to be a wee bit colder! My lake is 640 acres, 65' max depth and avg. depth of 20'. what should I buy? Advice? Thanks.
03-08-2006, 6:27 AM
personally I would get a drysuit. I have both and never wear the wetsuit anymore. I go from drysuit to shorts and a heater shirt. I usually wear mine till end of may and then after mid sept. I figure if I have it why bother being cold. Plus the drysuit is nice cause when you get in the boat you aren't freezing cold and dripping wet. Go with a O'neil Boost or barefoot international drysuit.
03-08-2006, 7:01 AM
after wearing a drysuit and then buying one this weekend, it is almost like cheating the cold. you will be in love with the thing in no time. no substitute. just remember you cant pee in them! whats shakin stan?
03-08-2006, 5:14 PM
Make it three for drysuit. I rarely wear my wetsuit anymore.
03-08-2006, 6:28 PM
wetsuit. way more comfortable, ur gonna get wet in a drysuit. one hard fall and ur "dry" clothes are wet around your neck, or arms or feet. plus the seems go after a while and then they leak. they can be repaired but it costs money. if you dont wear a few layers or sweats underneath the drysuit ur cold. with a wetsuit u jus pee and ur plenty warm. its wakeboarding. you get wet in wakeboarding. you get wet. even if you dont pee ur warm in 2 minutes. half the time im flushing the warm water outta my wetsuit with cold water to cool down. you have way more mobility in a wetsuit. and when u fall ur suit doesnt fill up with air and u dont feel like the stay puff marshmallow man. hahaha. plus ive taken hard falls in both a wetsuit and a drysuit. the drysuit doesnt buffer the slap of the water verywell. a wetsuit acts like a layer of blubber kind of like a seal
03-08-2006, 6:30 PM
Maybe I'm just crazy, but both are gonna keep you warm enough. High quality wetsuit will keep most water out and keep you warm, drysuit will keep you drier (and warm if you wear clothes under it). For me, it boils down to a style issue... and I don't think anyone will argue that there's absolutely nothing fashionable about a baggy drysuit. haha. I have a JetPilot Storm series wetsuit, and I hopped into my lake this January when it was measured at 43 degrees without any problem staying warm... swam around for 15 minutes in fact. This was at Lake Cavanaugh, WA... 8 miles around, max depth of 80', 844 acres It's largely a preference issue. Wetsuit= warm, minimalist, awkward if you have to get in and out of one in a boat. Drysuit= extremely dry, versatile, and less awkward to put on in a boat!
03-08-2006, 9:31 PM
OK, but do they make a dry suit that doesn't choke you to death? I've tried them on before and my face was red in about 30 seconds!
03-08-2006, 10:07 PM
Water temp above about 48 degrees, a wetsuit. Anything colder a drysuit is a must. Wetsuits allow much more flexability. Remember you still need to wear your life jacket inside a baggy style drysuit along with polar tec fleece or whatever your choice is.
03-09-2006, 8:58 AM
I was in limbo about whether to get a drysuit or a wetsuit. tried on a drysuit, and did not like how if felt. really tight around the neck and ankles. plus, the cost was pretty high. decided that the water I ride in, is really not thaat cold. low 50's at the coldest. went with a JP chamber. got a smokin deal on it. used it last weekend. water was mid 50's, and I barely felt it. like Jason said, I ended up flushing out the warm water with some cold water to cool down. way more flexible. I would say that if you are in water below 50 for multiple months, go with the dry suit. but if the water is in the 50's, go with a wetsuit. I highly recommend the chamber by JP. I love it!
03-09-2006, 10:22 AM
Drysuit all the way! I also feel my drysuit gives me way more flexability then my 3/2 did. Ive only ever got a very small amount of water in the neck of mine. As far as it being tight I dont even notice it after I get up.
03-09-2006, 10:25 AM
ttrigo, How much, where and mm?
03-09-2006, 10:41 AM
I got it new from a rep for under $200. the suit is a 3/2. I was seriously looking at drysuits, and just did not want to pay at first. then I changed my mind, and then I tried one on. and then I decided to check out a new full suit. this thread has a little info on it. http://www.wakeworld.com/MB/Discus/messages/1/282170.html?1139368341
03-09-2006, 11:35 AM
Chicago, I sent you an email.
03-09-2006, 12:51 PM
If you are going to take more than one set when you go out, then drysuit all the way! Also you could share the drysuit---not happening with wetsuit. I have both. Once I used the drysuit, I have not put my full wetsuit back on.
03-09-2006, 12:59 PM
I agree also. I don't ever see myself wearing a wetsuit again, however there are a lot of people that hate them. I think it's just like the "what boat should I buy?" question, you really should try both and make up your own mind.
