Parker, Just take a nice sharp utility knife and cut along the outside of the rail - it is OK to cut through the foam a bit since you will be probably shaping that down anyways. Once you've cut all the way around, you should be able to peel the fibgls off the foam slowly and carefully. you will probably be getting little chunks of foam here and there, but again, if you are reshaping it into a wakesurf, I assume you'll have plenty of foam to work with. good luck
