For years and years I have owned trailers that had the tongue jack built in, an integral part of the trailer. The jacks were always built into the center of the tongue and usually there was no easy way to replace them. Back in 2001 I bought a boat that came with a trialer from DHM. This trailer had a tongue jack that was mounted to the side of the tongue. I remember my first reaction when I saw that: "cheap!". I changed my mind on that after the first couple of times I used it. First off, I only had to crank it up far enough to get the load off, then pull a pin and rotate it up. So much easier! And it gets it way, way out of the way, no possible way that you can drag the jack wheel on the ground and destroy it. Best of all, it can be easily replaced! I think back on all the trailers I have had where the tongue jack was stiff, or the wheel was destroyed, and I simply lived with it for years.... Rod
