Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 18, 2006
Old     (depoint50ae)      Join Date: Jul 2005       05-23-2006, 8:01 PM Reply
How do these bindings compare to the CWB Zeus?
Old     (jarrod)      Join Date: May 2003       05-23-2006, 8:27 PM Reply
They are much stiffer with the same comfort. Same footbed and base.
Old     (antbug)      Join Date: Jul 2004       05-23-2006, 10:03 PM Reply
and watch out for the 07's. They are absolutely AMAZING.
Old     (depoint50ae)      Join Date: Jul 2005       05-23-2006, 10:16 PM Reply
jrod are the fuse stiffer or the Zeus?
I rode a Fuse bindings today and they were awesome. I was thinking about getting the Zeus one day but if they are pretty much the same thing or the Fuse are stiffer I think I would like the fuse bindings better.
Old     (allen)      Join Date: Apr 2005       05-24-2006, 6:43 AM Reply
The fuse are stiffer for sure
Old     (jarrod)      Join Date: May 2003       05-24-2006, 7:52 AM Reply
They are very different as far as support, but just as comfortable.
Because of the Hinge, the heel hold is a little better in the Zeus. The Zeus also allows for a lot more ankle movement for pokes / tweaks.
The Fuses offer a lot more support for those with bad ankles, like me. I feel a lot more solid and stable when I stomp down in the Fuses. They are a top notch binding that is often overlooked or overshadowed by the Zeus. This is because the hinge is so desirable that people rarely pick up a Fuse.
Just a heads up though, the 06 Fuses run a little tight. They fit Allen perfect right out of the box, but I had to stretch mine. They are the most comfortable ride for me. Also, the have the lycra on the inside so you can get in without lube.
(Message edited by jarrod on May 24, 2006)
