Weight isn't that big of an issue. If you aren't getting the full rotation, you are doing one of two things. 1. Taking off too early. The trick to the tantrum is to WAIT WAIT WAIT for the wake. Take a nice cut, and then level off (kinda surf the wake) about 3 feet from the bottom, then just push your chest upward. The trick will throw itself. 2. Not tucking enough. If you lay out a tanny, it looks sick, but if you are trying to learn it and just do em all layed out, you may be slowing the rotation down too much. To speed up the rotation, such your lead arm in at a 90 deg angle like an "L" to your body, and tuck your knees. This takes some getting used to. It will also keep the trick from looking super "tweaked". Unless you want it that way. Good luck!
