why are you changing the plugs?? In a boat due to the low temp's the plugs will last over 450 hrs. Anyone who tells you that they need to be replaced before that bacicly is trying to gross you (a dealer or a mechanic) or dosent know what the f**k they are taking about. as far as the trany goes it takes 1.5 qts of mercon/dextron if its a Mercruser, and type F trans fluid if its a PCM. Use the pump to pump out the trans. otherwise your going to make a mess out of the hull. The v-drive unit check with the owner’s manual, but if you don’t have one a syenthic gear lube such as a mobile one is a good way to go. It takes almost 2 its. Again use the pump to pump the fluid out of this too. I run 5w 50 if I am using syenthic and 15/40 if I go with conventional oil. Pick a brand you like. If you look at the back of the bottle you will see a SAE rating. Just about all oils are at least SG these days. The further down the alphabet the better the oil. I was at West coast Correct Craft the other day they use Car quest oil for all of there boats, and they are a Premier Dealer service center. Their clients tell obviously don't have a problem with $$ so that isn’t the issue. So anyone that tells you need Marine oil again doesn’t know what the F**k they are talking about. For you oil filter, take the new oil filter box, and tear off the box top and flaps. Put a couple of paper towels in it and use that to catch the excess oil and it will help you not get oil all over the boat as you carry it out. I don’t run the eng before I change my oil, that way you don’t have as much oil in the filter when you change it. Their are a lot of different things besides changing your fluids involved when doing a service. So don’t forget the grease zerks,shaft packing, trailer bearings, brake fluid in the surge brakes, cleaning the air filter, checking the torque of the prop and strut, and skags. Their are still things that are not listed here but this is a good start for you. Have fun...
