It really depends on what the source of them are. If they are being caused from your cover then they probably don't run that deep and can be sanded and buffed out. They are some threads on here as well about gel coat filler and you may have some options with it. However, you could also have a fiberglass problem too. By this I mean a weakness somewhere in the hull. Either way it is going to resort to your skills here, if you don't know how to fix it yourself then contact a good glassman in your area.
