I tend to banana peel out of backrolls now. I'm real close to sticking them, but, if you're underrotating, I can help. 1. Make sure when you pop off the wake, you're standing tall, or else you lose everything you had for the spin. 2. Make sure to look over your front shoulder behind you, so that you can spot the landing, and keep your eyes open. 3. Lean back some, and pull the handle towards your back hip when you release off of the wake. If you loaded the line right, that will initiate the spin, and it will take you around on it's own. 4. Like they said, keep the handle in tight, or else you'll either underrotate or pop the handle when you hit the water.
