Old     (gunner)      Join Date: Aug 2007       08-19-2007, 7:38 PM Reply
Just started surfing and I need some help weighing this old Nautique down to produce a good wake...any ideas??? Can it be done?
Old     (souperfly)      Join Date: Apr 2006       08-19-2007, 9:05 PM Reply
anything can be done with enough weight. I have a Malibu direct drive and surf it every weekend. Here's my setup:
440lb behind the engine
440lb next to engine
350lb in the ski locker
150 lead in the bow on surf side
150 lead on surf side, mid boat
150 lead in rear surf side.
Oh, and the wedge is down.. Malibu thing...Upload
Old     (dentard)      Join Date: Apr 2006       08-19-2007, 9:05 PM Reply
Weight, in one corner, and lot's of it. Then, buy a new boat when you see the size of other's wake. Curtis
Old     (sell)      Join Date: Nov 2006       09-30-2007, 7:12 PM Reply
Greg,
It can be done no problems. I have a 1980SN and we surf all the time.
I run 100 lbs of lead down the starboard side of the engine, 100 lbs in front of the engine & under the drivers seat. I also run a 330 lb fattue behind the engine & a 220 lb waterbed bag snaked from behind the engine & up the starboard side.
We usually only have 2 people in the boat & 1 riding.
Here is the wake,
Cheers,
Ken
Old     (wakemetoday)      Join Date: Mar 2006       10-01-2007, 11:32 AM Reply
I had a 78 Natique at one time and I found a Phat Seat was a wise investment. I never surfed behind the Natique but my 90 Ski Sanger had a better surf wake when I filled the Phat Seat about 1/2 full and then added the weight to one side. Try the 78 both ways, with weight all the way across the back and on one side. You might be surprised. Try to get front weighted down also. I put 50 lb. bags of sand in the front of mine. Be sure to cover them with plastic bags. Good luck and let me know how your weighting turns out.
Old     (luchog)      Join Date: Jun 2002       10-01-2007, 12:09 PM Reply
Ken, what prop are you running on your 80?
Old     (sell)      Join Date: Nov 2006       10-01-2007, 7:48 PM Reply
Luciano - Standard 13x13 3 blade.
For the record, I use less fuel wakesurfing than wakeboarding with 220 lbs less ballast....
I can't wait to get my new starter so we can get back out there, Air temp over here is regularly hitting 88 F....nice
Old     (luchog)      Join Date: Jun 2002       10-01-2007, 8:32 PM Reply
I'm tring to get started with surfing.
I thought that since the old nautis were RH propped you would ride on the other side of the wake. how's this¿?
Old     (sell)      Join Date: Nov 2006       10-02-2007, 3:27 AM Reply
RH Prop = Starboard side
LH Prop = Port side
These are generalisations of course as some of the bigger boats can get good surf wakes on both sides.
