Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through March 13, 2007
Old     (sroot1)      Join Date: Aug 2005       03-05-2007, 1:50 PM Reply
I would like to replace all of the open cell egg crate foam inside the engine cover and stern engine bay wall.
Does anyone have a source for closed cell foam that will not suck-up water and still provide good sound dampening?
Thanks! Scott
Old     (masonwakerider)      Join Date: May 2003       03-05-2007, 7:19 PM Reply
theirs a company called EAR that makes marine sound deadening foam, they have quite a few choices, thickness and material some have a layer of lead some are adheisive backed. in the seattle area it is sold at Fisheries supply (206) 632-3555, i havnt been able to find them online.
Old     (rallyart)      Join Date: Nov 2006       03-05-2007, 9:16 PM Reply
http://quietsolution.com/html/marine.html
http://www.marinefoam.com/marine-soundproofing.html
These are a couple of real solutions. If you are looking at products see if they give you an STC rating. The higher the rating the more dB reduction and they have to test a product to get those numbers.
I'm sure there are lots of other products too.
(Message edited by rallyart on March 05, 2007)
Old     (retrofridge)      Join Date: May 2005       03-06-2007, 11:46 AM Reply
Scott this is one of the companies that supplies the foam for your boat
http://www.noviconusa.com/home.html
Old     (sroot1)      Join Date: Aug 2005       03-07-2007, 8:41 AM Reply
Everyone Thanks for your input!
Have you guy's tried any of these foam products?
If so did you notice any difference in cabin noise?
Old     (rem_pss308)      Join Date: Mar 2004       03-07-2007, 10:34 PM Reply
I know guys on tmcowners.com have used spray on bed liner under the engine box. they say it helps a lot.
Old     (rallyart)      Join Date: Nov 2006       03-07-2007, 10:45 PM Reply
http://www.qlmarine.com/ql.asp
This is Volvo's QL accessory line.
Old     (sroot1)      Join Date: Aug 2005       03-10-2007, 6:45 AM Reply
Everyone Thank you for your input!
Looks like the 1 3/8" foil faced multi-density foam will work on the engine box and wall.
What type of insulation product do you see used on direct or V-drive engine compartments?
