Brian,
What year VLX do you have? What prop do you have on your boat right now?
I am by far no prop expert, but I did just switch over from the ACME 1939 to the OJ Fusion 532 on my '11 VLX. It made a significat difference in the holeshot/low end compared to the 1939. I spent the last couple seasons with my old boat using the ACME 1235 which after using the 532 is very comparable. If you are looking for a good wakeboard/surf prop might want to look into the 532 or ACME 1235. After taking the boat out with the 1939 I knew right away I would be going back to the 1235 or 532. I felt the boat had a difficult time getting on plaine.... however, you will loose some top-end performance with the 532, but cruising in the 30-35MPH range still is do-able, you will probably top out around 41-42 MPH.
Just my opinion.... I am sure others here will also have some good feedback for you. There are a lot of prop options available.... Eric at OJ props has been great to deal with, he is the expert and can probably anwer all your questions.
