Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 06, 2007
Old     (bhog)      Join Date: Jul 2006       07-31-2007, 11:00 AM Reply
I have searched but cant find info. My buddy has this boat and we have tried so many different ways. Its always a little washed out. We have stock ballast 900 and 2 400pound saks. Any info or suggestions would be appreciated .
Thanks
Britt
Old     (denverd1)      Join Date: May 2004 Location: Tyler       07-31-2007, 11:01 AM Reply
how fast?
Old     (bhog)      Join Date: Jul 2006       07-31-2007, 11:09 AM Reply
23.5 on the PP and 75ft rope. Not sure how accurate that is. We been putting most of the wieght up front too, if that helps
Old     (denverd1)      Join Date: May 2004 Location: Tyler       07-31-2007, 11:29 AM Reply
start empty and see where it cleans up, what speed.
then start adding.
Old     (masonwakerider)      Join Date: May 2003       07-31-2007, 12:45 PM Reply
If that is the speed and length you like to ride with then and the wake is washy,with the stock full put all your weight in the bow and start to drain the rears as you drive. Stop drianing when it cleans up. Your other option is to speed up a little bit.
Old     (bhog)      Join Date: Jul 2006       08-01-2007, 10:43 AM Reply
bump. No one one here rides behind a x30?????
Old     (prostartjh)      Join Date: Nov 2006       08-01-2007, 10:15 PM Reply
I have an '02 X30 and we ride with two fat sacs (750lbs. each) on each side of the engine. They are only filled up 1/2-3/4 of the way. The center ski locker has a custom made sac that holds 400 lbs. I removed the stock tanks in mine.
