Here is what I have done. I almost always run the stock MLS (1250), and I have 400 in lead that I usually put in the walk through, on the floor. On a couple of occasions, I have put a 400 lb bag on each side of the motor. No problems getting on plane, and that is with 5-6 persons in the boat. The only time I have had trouble getting going was with all that weight, 8 persons, and the wedge down. As soon as I put the wedge up, it took a bit longer, but not much problem to get going. And the wake was sick! Like I said, I usually run stock 1250 lbs ballast, and 400 in lead. Usually most of it up front, but sometimes I leave a couple in the rear. That seems to be plenty of wake for just about everyone.
