Old     (laraujo)      Join Date: Apr 2007       05-06-2008, 3:45 PM Reply
Can you use a Tsunami pump (portable with adapter type) to fill a Launch Pad fat sac. Is there a way to connect it to the Launch Pad Fitting cleanly so that you can fill and drain without getting water all over. If so.. what fittings do you use?
Old     (libertylake)      Join Date: Jul 2007       05-06-2008, 4:05 PM Reply
You can order the quick release connectors from Straight Line or some of the other online stores. Cut off the existing connectors that came with the Tsunami pump then re-clamp the straight line connectors. Presto you have a Tsunami pump with Straight Line connection and no leaks.
Old     (wakemikey)      Join Date: Mar 2008       05-06-2008, 4:31 PM Reply
Not sure if they have it but try here
http://www.wakecord.com/fat_sac_connectors.htm
Old     (trdon)      Join Date: Sep 2007       05-06-2008, 6:05 PM Reply
The tsunami pump comes with the blue plastic adapter to fit the older style sacs.
Old     (laraujo)      Join Date: Apr 2007       05-07-2008, 8:23 AM Reply
I have the blue plastic adapter.. Is that what is used on the fittings of the Launch Pad Series sacs? thanks in advance everybody
Old     (sangerlover)      Join Date: Sep 2005       05-07-2008, 8:36 AM Reply
The uber pump from launch pads comes with both the "no leak fitting" and the plastic blue adapter. You can use the blue adapter but like I say you will have a few gallons of water in the boat. You can buy the uber pump fitting at wakeside.com and then should be able to attach that fitting to the Tsunami pump
