Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 01, 2004
Old     (wakejumper8)      Join Date: Sep 2002       03-30-2004, 9:36 AM Reply
Can anyone help me out with proper weighing of a 2001 SangAir?
Old     (dakid)      Join Date: Feb 2001       03-30-2004, 9:44 AM Reply
Fat Seat (approx. 1400lbs) in the back, a full size sac (approx. 500lbs) in the front.
Old     (thor)      Join Date: Oct 2001       03-30-2004, 12:09 PM Reply
Joe a fatseat would perfect in most Sanger boats, but unfortunately the 2001 SangAir has an internal ballast tank under the rear seat making it difficult to remove.
In my boat, I run to 600 lb. sacs on each side of the engine, 1-250 lb tube sac in the front and the 320 lbs of internal ballast in the rear. Add to this at least 6 people and the wake is really nice. Just my opinion, but it works great for me.
Old     (dakid)      Join Date: Feb 2001       03-30-2004, 12:14 PM Reply
Good point, Rob. I totally forgot about the internal ballast.
What about lead in the rear compartment, along with the sacs on the side? Will that work?
Old     (wakejumper8)      Join Date: Sep 2002       03-30-2004, 1:14 PM Reply
I appreciate this guys. I have lead and am playing around with it, but have not found the perfect wake yet. I'm going to add fat sacs this weekend and need the advise.
Are there any problems to adding the weight (lead) in the ski lockers which is on top of the ballast tank? Could this cause damage?
Also, can weight be added in the hull (under the ice chest in the middle)?
Old     (blastmaster)      Join Date: Aug 2001       03-30-2004, 2:23 PM Reply
Laurie:
I have a 96 dlx which is the same hull. I run about 500 lbs lead mostly in the ski locker and under front seats. I just added a thru hull and pump that will feed a bag under the ice chest for additional 400lbs try your weight forward. It sinks the whole boat better. I would not put lead on the plastic tank. A big wake could rupture the tank, espcially if its not full with water to help carry the weight.
Rick
