Finally got the stereo done. Installed and working properly. Its been a long road for this the past winter but with the expertise of Exile, and Sub Zero my boat is rocking
Stereo
Kenwood 700U with on-board Remote controls the Tunes
6 Polk DB 651.s are in the cabin for the peeps
4 XM7s on the tower for the boarders
1 Exile Big 12 sub woofer to scare the fish away
1 Custom sub enclosure made by Sub Zero and Exile
Exile 800.4 powering the cabins
Exile 1500.1 powering the sub - with separate volume control
Exile 1k Harpoon powering the tower - with seperate volume control and Throttle box control for Wake board Distance or Wake Surf distance tuning.
For the record i did 100% of the install.
All connections are heat shrunk
Power and Ground lines are Fuse protected.
Power and ground to the distro blocks are 1.0 gauge
Power and ground to the amps are 4.0 gauge
Remote Power to amps is 14 gauge
Speaker lines are 14 gauge
I have 3 batteries currently. 1 as the main starting battery. 2 as the Stereo Batteries.
All Battery jumper cables are 2.0 gauge
When you open the cubby you see no wires from my install i tried to keep everything hidden from the normal view and you have to look up or behind the bulk head to see any wiring that is traveling to the different systems.
I kept my power and ground on 1 track threw the boat and my RCAs on another track threw the boat.
