Did you feel any kind of strike? Usually, vibration is caused by prop issue. May not be the case here but on newer boat like this, that would be the first place I looked. Have you been able to determine where the noise is coming from? The squeal makes me think there could be something else going on and maybe something struck your shaft and then hit your prop causing that ding....just thinking out loud here.
Hope it ends up being an easy fix for you. Nettle Props out of Austin TX is where I sent mine for repair...they do a good job and have a lot of experience.
