My normal wake setup is a 350lb vdrive sac on top of 3 50lb steel plates in each locker, the center bag as full as I can get it, two steel plates in the bow walkway, about 240 lbs of lead under the front seats, and two more steel plates and a little 80lb fatsac in the cockpit for adjustments. When I surf, I move one of the rear locker bags over the the locker of the side I'm surfing on, and take two of the plates and move them from the rear locker and into the cockpit on the side I'm surfing on. I take all the weight in the cockpit and move it over. Then I fill up a extra locker sac I've got and fold it up on top of the steel plates in the cockpit. I usually put the little 80lb fat sac on the rear seat. This setup works very well when you only have two people going out (my wife and I are usually the only ones in the boat when we surf). It may need to be tweaked if you have a fair amout of people. riding with you.
