Yes,it is plugged in I think I will check the fuse. It was fine at thew end of the season last year first time out this year not working. anything else I should check??
I had mine freeze up on me. The dealer replaced it under warranty. If it won't move when the engine is off, then it is bad. It should not move whne the engine is on though.
Well it is not froze up turns fine with engine off also turns when engine is on so it is acting like there is no power to the servo motor. Perfect Pass website says to check the fuse I will look at it tommorow.
